Kako ugotoviti kakšno je razmerje diferenciala...
you can actually "count" the diff ratio.
on ladaclub.hu in the hungarian section is my method posted.
briefly it is the following:
lift one wheel of the questioned diff, other side remains on ground.
take a chalk to set marks on the driveshaft (where you can see it
without crawling below the car) and on the outside of the lifted tire (i
prefer to mark the 12 o'clock position)
i watch the mark on the driveshaft while slowly turn the wheel in one
direction. (say clockwise) i count 8 times the driveshaft mark passing
by, and at the 8th occurrence stop the mark with the wheel.
now look on the wheel where moved the initially 12 o'clock mark.
if the diff were with 4,00 ratio (there is none of this kind) the mark
would stay on the very top position again. if the wheel was turned
clockwise while counting,
and the wheel mark halted just after 1 o'clock, the diff is 3,909.
if the wheel mark is around 11 o'clock, the diff is 4,1
if the wheel mark is short before 9 o' clock, your diff is 4,3
if the mark is at 7 o'clock, you have the very short 4,444 ratio 2102
type diff installed.
gm.
www.ladaclub.hu
diff ratio
