niva greece
niva greece
niva greece
OdgovorNapisal/-a niva greece » Po Jul 25, 2005 3:25 pm
hallo from Greece
I have a LADA niva 17i and I search wich way to get 7 cm higher in this moment i have a panel+ 3cm and wears 205R16 you know how?
thanks
slayer
Prispevkov: 2042
OdgovorNapisal/-a slayer » Po Jul 25, 2005 3:31 pm
FOr front or rear axe?
SOme pictures you will find here:
http://www.nivaoffroadteam.com/?page=mods/lift_gregor
Its the part of this page.
:wink:
slayer
Prispevkov: 2042
OdgovorNapisal/-a slayer » To Jul 26, 2005 4:33 pm
On the front dont lift too much... If u lift 3 cm on the front spring and 3 cm on the ball that is enought. That is about 6 cm total lift. 3 cm on the ball is maybe too much. You lose optic performance of your niva. And it be inefficient to drive on the asphalt road.
For rear axe i recommend you lift for about 5 cm. If you go more then 5 cm you will break the propulsion from the central diferencial.
If you drive only off-road with your niva you can go for about 1-2 cm higher on each axe. But on your own responsability. I dont recommend yout. Buy higher wears. :roll:
And sorry for my bad english. :oops:
niva greece
OdgovorNapisal/-a niva greece » Sr Jul 27, 2005 7:08 pm
I believe my English is very bad :cry:
I don't believe it is the 6 cm height, because from palls you don't take any height
that you have made in the base of spring it is good and safety?
have you any problem from the additional height ?
make preparations for trophy and I have put crown & pinion 4:3 from 3:9 that it had and I want the height in order to I put bigger tyre, the 205/80/16 it finds in the dome.
nivaklub
niva1.5 president
OdgovorNapisal/-a nivaklub » Če Okt 20, 2005 4:40 pm
pozdrav
iz
budimpeste
www.niva4x4.hu
nivaklub@yahoo.com
ferrarist
Prispevkov: 1488
Kraj: okolica ajdovščine
OdgovorNapisal/-a ferrarist » Če Okt 20, 2005 6:34 pm
hehehe...kaka lepa rožica :twisted:
