R.A.T.
Romanian adventure throphy
14.-20. 06. 2013
Offroad tekmovanje s poudarkom na orientaciji v naravi. Sodelujeta dve kategoriji vozil:
- Navigator: predelana vozila, cevni prototipi...
- Hobby: registrirana terenska vozila
Tekmovanje se vrši od 14.06-20.06 2013 v osrčju Transilvanije. Nepozabna avantura, 5 dni, cca.800 km. Spanje v kampu ali penzionu. Katering, zjutraj in zvečer.... cenovno ugodno. Več informacij na tel: 0038641617345
Ogled tudi na strani: www.therat.ro
LP Franci
R.A.T. Romanian adventure throphy
Zadevo se je dalo dodobra spoznati minuli vikend, ko je bila organizirana predstavitev in preizkus v naravi v okolici Kopra.
Na vsak način zadeva ni za tiste, ki nimajo ustreznega vozila za pravi teren. Pa tudi škoda ti ga ne sme biti (veje, skale, ...). Zadeva je tekma in ne družinski izlet. Treba je obvladati navigacijo in vožnjo po zahtevnem terenu.
Brez vitla je zelo težka.
A zabava in užitki za udeležence so zagotovljeni!
Video iz naše lanske udeležbe http://youtu.be/kDwbDpVvwuo
A ni vse tako "hudo". Ponekod je prav lepo.
Nazadnje spremenil miran, dne Pe Maj 17, 2013 3:06 pm, skupaj popravljeno 2 krat.
Evo še odgovor od njih:
Briefly:
Every day you will get a map.
On the map you will have figurate some points, named check-points - CP, classified on order from 1 - 20.
The maps will be 1:100.000 topographic.
Start point will be on the campsite, and from the start point to the CP1 you will have the azimuth in degree and the distance in meters/kilometers.
In this way you can project the CP1 on your map, and navigate to him in most convenient way.
Once you get the CP1 you will project CP2 and same story.
You can use compass and rulers as well as navigation systems what you have it on the car.
Of course if you will decide about the most easiest way to rich the CP, you will have the longest track, but you will protect the car about scratches/damages.
You will need to built a strategy every day because not all the CP are easy to get, or you will have not enough time to get all of them.
During every day you will have a "two hour window" when it is open a special stage where you can get 5 CP by completing a short special track with 5 gates.
Every gate = 1CP.
On your strategy you need also to include this "two hour window".
So:
It's about smart navigation.
It's about driving skills.
It's about clever strategy.
It's about adventure, inspiration, friendship and discover.
any other information feel free to ask
Thank you for your interest
Hope to see you soon.
Bucur Milancovici
Briefly:
Every gate = 1CP.
So:
Bucur Milancovici
Živjo matko88,
Lepo, da si želiš sodelovat na kakšni dirki, vendar pa glede na tvoje dosedanje izkušnje (oziroma glede na tvoje dosedanje prispevke na forumu) bi bilo mogoče pametneje, da poskusiš in okusiš draž offroada ne kakšni malo lažji prireditvi (naprimer na v Brdih http://www.nivaoffroadteam.com/forum/viewtopic.php?t=14984), kajti RAT res ni primeren za začetnike, še posebej ne z boljšo polovico kot sovoznikom(in še posebej ne, če jo je treba za to prepričevat). Do tam je namreč cca. 1000 km, po dirki pa treba še domov priti, med dirko mora sovoznik aktivno sodelovat pri navigaciji, branju roadbooka, iskanju checkpointov, mora vleč zajlo, itd... Kak drużinski izlet to vsekakor ni. Kako je s tvojimi izkušnjami ne vem, sodeč po tvojih postih pa nevemkakšen offroader tut nisi, tako da ti (po svojih laičnih izkušnjah) svetujem, da se najprej poigraš v Brdih, potem odpelješ kak hrvaški roadbook (križevci, katun, dalmacija 4x4), šele nato pa se podaš v 1000 km oddaljeno Romunijo na loterijo... Lani je na One trophy-ju vrhunsko pripravljeni toyoti odpizdilo polosovino, po treh dneh še zadnji diff, pa je bil avto pred dirko na novo narejen, pa voznik z dolgoletnimi izkušnjami, pa vedel je, kateri tip toyote vozi.... a TR al GR.... in vsaka taka okvara stane tam, in the middle of nowhere, cca 500€, pol pa računaj... drgač pa, če si tega res želiš, pol pa strica Mirana poslušaj, telefonska je tut napisana....
Pa brez zamere. Upam, da se srečamo v Brdih in kakšno rečemo...
@kloshar
Ne skrbi, ni zamere
Se kr strinjam s tabo, bo še žal treba malo počakat. Ampak na teh standardnih tekmah mi ni v interesu sodelovati saj nikjer ne omenjajo podobnih stvari kot tukaj (topologija in pridi na točko kakor veš in znaš) in to me je najbolj pritegnilo. Upam pa da bo na sporedu prej kaj takega, da nebom rabil čakati eno leto na to
Ne skrbi, ni zamere
