RAZLIKA V DIMENZIJI GUM 31X10,5X15 -- 32X11,5X15 ?
Roger
Prispevkov: 205
Pridružen: Sr Nov 09, 2005 5:55 pm
Kraj: Vasi pod Stolom
OdgovorNapisal/-a Roger » Če Feb 02, 2006 12:57 pm
Zanima me koliko je slednja guma višja in širša od prve?Za točen (čimbolj)odgovor se zahvaljujem.Guma BFGoodrich Mud-Terrain T/A. L4x4p Vojc
OdgovorNapisal/-a Nebivedu » Če Feb 02, 2006 1:13 pm
Malo grdo pride tak izpis, zato si raje tukaj preveri razliko:
http://www.1010tires.com/TireSizeCalculator.asp
31 x 10.5 R 15
31 zunanji premer v palcih = 78,74cm
10.5 širina pnevmatike v palcih = 26,67cm
15 premer platišča v palcih
32 x 11.5 R 15
32 zunanji premer v palcih =
11.5 širina pnevmatike v palcih
Stock Tire - 31x10.50R15 32x11.50R15
Section Width: 10.51 in 267 mm Section Width: 11.49 in 292 mm
Rim Diameter: 15 in 381 mm Rim Diameter: 15 in 381 mm
Rim Width Range: 7 - 9 in Rim Width Range: 8 - 10 in
Overall Diameter: 30.97 in 786.63 mm Overall Diameter: 32.01 in 813.05 mm
Sidewall Height: 7.98 in 202.69 mm Sidewall Height: 8.50 in 215.9 mm
Radius: 15.48 in 393.19 mm Radius: 16.00 in 406.4 mm
Circumference: 97.29 in 2471.1 mm Circumference: 100.5 in 2552.7 mm
Revs per Mile: 671.6 Revs per Mile: 649.7
Actual Speed: 60 mph 100 km/h Speedometer1: 58.0 mph 96.7 km/h
Speedometer Difference: - Speedometer Difference: 3.370% too slow
Diameter Difference: - Diameter Difference: 3.25%
OdgovorNapisal/-a marolt 4x4 » Pe Feb 03, 2006 8:02 am
za eno colo je višja. 25,4 mm.
OdgovorNapisal/-a Gost » Pe Feb 03, 2006 11:11 am
...pa širša tud za eno... kdo bi si mislil? :lol:
