Živjo!
Pojavil se je problem. Se ne spoznam toliko na zavore in olja za le-te.
Torej zanima me razlika med DOT3 inu DOT4. Na pokrovčku mi piše naj uporabljam samo trojka ampak na Petrolu imajo samo štirico.
Kaj naj sedaj nalijem?
DOT 3/4
Preberi tole: http://www.ducatimonster.org/faq/faq_brake_fluid.html
Pomoje je vseeno če ti piše DOT3 in točiš DOT4. Mislim da ne more škodovati.
DOT4 fluid, for a slight increase in cost, will give significantly increased resistance to moisture absorption, thus decreasing the likelihood of corrosion compared to DOT3. DOT4 fluid has a higher boiling point than DOT3, making it preferable for high performance uses such as racing, autocross, or excessive use of the brakes in mountainous areas. For even greater braking performance, consider going to DOT5.1 or a high-performance version of DOT4 fluid.
When changing from one fluid type to another, as a minimum, bleed all of the old fluid out of the system completely. For best results, all the seals in the system should be replaced.
kr en
