Ali ima kdo že kakšne izkušnje s sestavljanko reduktorjev (rocklobster) iz reduktorjev od SJ410 in SJ413? Zveni kot solidna rešitev za malo $$....??
pa še povezava:
http://www.geocities.com/Baja/Outback/3574/Rocklobster.html
krajši reduktor za samuraja
D&G Tuning Low Budget 4,16 gear set
This kit does NOT include gears. We give the possibility to our customers who have already the 410 gears and the samurai gears, to send their own 2 cluster gears. We treat them to 1 single cluster gear. We make them free of any vibrations. Now you can run a cheap 4,16 gear set for your Jimny offroad machine! With this low budget you will have 20% hi range reduction, 94% low range. To install the 4.16 samurai T-case under the Jimny you need the Jimny T-case conversion kit.
za vec informacij se obrni na www.dgtuning.com
PS:low budget 4,16-150€
4,16-500€
6,1-700€
4,16-500€
6,1-700€
lp zuki
