An expert is somebody who learns more and more about less and less until one day they know absolutely everything about nothing.
Citat dneva
Citat dneva
Here are some of the WD40 uses:
1. Protects silver from tarnishing.
2. Removes road tar and grime from cars.
3. Cleans and lubricates guitar strings.
4. Gives floors that 'just-waxed' sheen without making it slippery.
5. Keeps flies off cows.
6. Restores and cleans chalkboards.
7. Removes lipstick stains.
8. Loosens stubborn zippers.
9. Untangles jewelry chains.
10. Removes stains from stainless steel sinks.
11. Removes dirt and grime from the barbecue grill.
12. Keeps ceramic/terra cotta garden pots from oxidizing.
13. Removes tomato stains from clothing.
14. Keeps glass shower doors free of water spots.
15. Camouflages scratches in ceramic and marble floors.
16. Keeps scissors working smoothly.
17. Lubricates noisy door hinges on vehicles and doors in homes
18. It removes black scuff marks from the kitchen floor! Use WD-40 for those nasty tar and scuff marks on flooring. It doesn't seem to harm the finish and you won't have to scrub nearly as hard to get them off. Just remember to open some windows if you have a lot of marks.
19. Bug guts will eat away the finish on your car if not removed quickly! Use WD-40!
20. Gives a children's play gym slide a shine for a super fast slide.
21. Lubricates gear shift and mower deck lever for ease of handling on riding mowers.
22. Rids kids rocking chairs and swings of squeaky noises.
23. Lubricates tracks in sticking home windows and makes them easier to open.
24. Spraying an umbrella stem makes it easier to open and close.
25. Restores and cleans padded leather dashboards in vehicles, as well as vinyl bumpers.
26. Restores and cleans roof racks on vehicles.
27. Lubricates and stops squeaks in electric fans.
28. Lubricates wheel sprockets on tricycles, wagons, and bicycles for easy handling.
29. Lubricates fan belts on washers and dryers and keeps them running smoothly.
30. Keeps rust from forming on saws and saw blades, and other tools.
31. Removes splattered grease on stove.
32. Keeps bathroom mirror from fogging.
33. Lubricates prosthetic limbs.
34. Keeps pigeons off the balcony (they hate the smell).
35. Removes all traces of duct tape.
36. Folks even spray it on their arms, hands, and knees to relieve arthritis pain.
37. Florida 's favorite use is: "cleans and removes love bugs from grills and bumpers."
38. The favorite use in the state of New York WD-40 protects the Statue of Liberty from the elements.
39. WD-40 attracts fish. Spray a LITTLE on live bait or lures and you will be catching the big one in no time. Also, it's a lot cheaper than the chemical attractants that are made for just that purpose. Keep in mind though, using some chemical laced baits or lures for fishing are not allowed in some states.
40. Use it for fire ant bites. It takes the sting away immediately and stops the itch.
41. WD-40 is great for removing crayon from walls. Spray on the mark and wipe with a clean rag.
42. Also, if you've discovered that your teenage daughter has washed and dried a tube of lipstick with a load of laundry, saturate the lipstick spots with WD-40 and re-wash. Presto! Lipstick is gone!
43. If you sprayed WD-40 on the distributor cap, it would displace the moisture and allow the car to start.
WD40, angle grinder and a welder is everything what man need in his life
Tale tema bi lahko imela naslov: "Ura angleščine - višji nivo".
No pa (zaresno) šalo na stran:
Vse te super lastnosti tega proizvoda (a se nismo nekoč na vse pretege jezili, ko je nekdo nekaj podobnega reklamiranju objavil tu na forumu???), ki ga vsi poznamo zlasti po uporabnosti iz točke 43 v Klošarjevem prispevku -> so mišljene resno
ali bolj za šalo?
Če bi bile za šalo, bi bila vmes verjetno tudi kakšna v tem stilu:
"Keeps your wife away from your favourite bar"
Če so torej mišljene zares, sem pa prav hvaležen za zelo koristne nasvete, reklama gor ali dol.
miran napisal/-a:Tale tema bi lahko imela naslov: "Ura angleščine - višji nivo".
Vse te super lastnosti tega proizvoda (a se nismo nekoč na vse pretege jezili, ko je nekdo nekaj podobnega reklamiranju objavil tu na forumu???), ki ga vsi poznamo zlasti po uporabnosti iz točke 43 v Klošarjevem prispevku -> so mišljene resnoali bolj za šalo?
stvar je bila na originalni spletni strani mišljena resno! se pa meni zdijo smešne točke 5., 38. in 42.
